How low did you go in temperature? (and can you go into your profile settings for this forum and mark that you have a UM3?).
I'm doing some prints right now on a UM3 and had to lower by 10C to stop stringing. Don't be afraid to go all the way down to 180C.
Although I have to say the final picture looks quite good as far as strings are concerned. Towards the end (top) it stopped retracting because Cura won't let you retract more than about 20 times on the same spot of filament (or you can grind the filament - in fact I usually set this to 10).
So I think you were successful.
Thanks for getting back to me so quickly. I have already tried going down to 185C and didn't see much improvement. Just wanted to clarify that the top image at 0.06mm looked normal for that layer height? Thanks again for your help.
PS. I have set that I have an Ultimaker3 for you
gr5 2,210
