Hi, thanks for reply;
i also suspected a power issue, i already tried to powerup fans, temp-up plate and nozzle, in this way seems to remain all powered on; seems to go off/on after a bit of stress when all parts are in movement, i also noticed the leds fade intermittently a bit before the issue. I see the nozzle fans, but i I can hear other fans, probably internal, can i access to them ? What other can i check ? Eventually, can i replace these parts ?
regards, Gianluca.
DidierKlein 730
Does it happen maybe when the fans are going on?
Might be the power supply, or an electronic issue.
You can maybe check without printing, by setting the heated bed temp, then the nozzle temp and activating the fans (all from the menu). This might show when it's rebooting
