Thanks for your advises.
I already have a speed of 30 mm/sec and the temperature is 200 degrees. I am quiet happy with the result exept for that stringing between the end and the beginning of a layer.
The extruder should retract at the end of a layer and not at the beginning otherwise the retraction is useless.
Is there another box to check?
I could fix that issue by having the same point for the start/end of a layer. In that case no more stringing.
Any idea how to do that?
gr5 2,210
I'm confused. You want to *uncheck* retract at layer change.
In general you can improve underextrusion and stringing issues by cooling the temperature by 10C and set ALL printing speeds (especially infill speeds) to 30mm/sec.
