If you have an Ultimaker 2, change your G-code flavor to "Marlin". This will give you full control over material settings in Cura, including cost.
I'm actually having the same issue I'm using 2.3.1 The Materials Tab The Information then Properties. All the cost section is Un Usable.. Yes i'm on Marlin. I can edit Everything else as it seems.
Material cost was not properly implemented until Cura 2.4 (or even Cura 2.5, I can’t remember)
Edited by Guest-
1
- 1 month later...
My materials have been set correctly as well as my printer. All the settings are correct including the price ones in the material, it even shows me the cost per meter in materials, but Cura refuses to show price calculation.
As you can see in the screenshot
- 11 months later...
Could you solve this issue??
I have the same problem, could you help me please?
- 5 months later...
I've already put the total cost next to the filament length for 4.1 (you're not the first to ask for it!)
1
- 2 years later...
If you want to bulk-enter the weight and cost fields, there's a neat little plugin to create a CSV file you can edit in your favorite spreadsheet application and import back into Cura:
https://marketplace.ultimaker.com/app/cura/plugins/fieldofview/MaterialCostTools
nallath 1,124
Uh, do you have a machine with materials?
