That explains the issues I've had with it. Had it working once, but showing the Ultimaker buildplate, which I corrected. I kept trying with it - noticed that the mesh had issues, so I ran it through netfabb to correct that. Since I posted the stuff, I haven't been able to make it work again.
Sigh.
Thanks for your efforts - they make excellent large-volume printers.
ahoeben 1,849
I've had a quick look at your definition files, and am willing to do the work to create a Pull Request over at github.com/ultimaker/cura for you, but have you tested these files? There's a number of typos in them (wrong double quotes (thanks TextEdit!) and typo in the plus_single for the mesh filename), and the buildplate mesh does not fit the buildvolume:
The mesh is smaller than the build plate, and lies on top of the build plate.
Edited by GuestLink to post
