Unwanted prime blob custom FDM dual extruder
focussoft
Posted · Unwanted prime blob custom FDM dual extruder
i been having problems with cura 2.7.0
everything works perfect ,except my printer randomly puts a prime blob on my print after switching extruders
i tracked down the problem in the . gcode file generated by cura
It inserts G1 F1200 E11 after switching extruders
it only seems to do it when the prime tower is activated
right now i use the "post processing plugin" to "search and replace" G1 F1200 E11 with ;G1 F1200 E11
and that works , it still goes to the print coordinates , but does not put down a prime blob
anyone know how to make cura stop inserting that G1 F1200 E11 code ?
The prime blob option in cura is "hidden by the current machine"????? i dont know why because its the machine profile is set up having 2 extruders and the rest of the build platform adhesion options are not hidden, neither are the dual extrusion options
T0 <------------ start code extruder T0
G92 E0
G90; Absolute Coordinates
G92 E0; Zero Extruder
G1 Z10 F9000
G1 X-20 Y40 Z0 F4800; Move X Y for tool change
G1 E120 F4000; Fast insert 120mm
G90; Absolute Coordinates <---------- end start code extruder T0
M109 S200 <---------- start generated code by cura
M104 T1 S0
G0 F5400 X98.147 Y97.862 Z0.4 <----------print coordinates
G1 F1200 E11 <<<<<<<<--- code extruding 11mm !!!! Blob !!
G0 F5400 X98.147 Y107.862 <--------- continue print ??
G0 X35.666 Y168.868 <--------- prime tower at x40 y170
    Hi. I don't use multiple extruders so I have no experience in this area but if you want to be able to disable the prime blob I think your machine definition needs to have this in the overrides section to make that setting visible:
    "prime_blob_enable": { "enabled": true },
    See ultimaker3.def.json for an example...
        • 29 replies
