Well im a few years late but I know this is the solution to the original problem and hope it helps someone. Once Cura starts up fallow the below tabs is that doesn't make sense I attached a photo too.
ONCE YOUR IN CURA
Preferences > Configure Cura > Settings > Build Plate Adhesion > Extruder Prime X Position OR Extruder Prime Y Position, you can also turn the blob at the end off or on as well in that same area. 😃
Edited by jeremyfiller1986Typo
DidierKlein 726
Hi and Welcome,
I don't know what version you are referring to but if you print a skirt (you can find this under platform adhesion in Cura 2.xx) then it will print one or more lines outside of the actual model, i guess this can be considered as a test strip and ensures that the print head is actually spitting out filament.
Usually the print head is priming enough but this depends on your printer and start.gcode
geert_2 462
If you print 4 or 5 "skirt" lines around the object, this also allows you to verify and if necessary fine-tune the distance between nozzle and print bed (at least on UM2 printers, I don't know if this still applies to UM3).
