tinkergnome 918
What version of Cura did you get the values from and what machine was used?
My screenshot is Cura 2.7, Ultimaker 3.
Looks like a single extruder machine in your case, or the visibility of this setting is disabled (you can check the latter by a click on the small gear icon).
If you're in need for a dual extruder machine definition for Cura 2.7 / UM2+ you can start with the Mark2 definition. You probably have to adapt the start script, but apart from that it should be pretty close to your needs.
Don't expect great prints with your setup (i think you already know the problems with heat transfer and inactive nozzles scratching the surface...) - but you asked for Cura, not for the hardware setup...
I redefined the machine set up in 2.7.0 and got the second extruder settings for support and selected successfully. But the printer still only prints with one nozzle, I can swap the extruders round and the support, which is on the second extruder, prints OK. So I must be missing something else.
The images below show the current setup.
tinkergnome 918
Hi Graeme,
it seems like you already have a working (DIY) printer definition with two extruders, right? I would use the search bar in Cura to search for "support"
This shows up all related settings, including support speed and support extruder.
