Heat block to 180C. Get a heat gun and blow on that blob and be very patient. Remove bits at a time. Use tools like toothpicks or popsicle sticks or a screwdriver or pliers. And be patient. it takes a long time.
If you dont' have a hot air gun and if this is PLA then a hair dryer will probably also work.
You might be lucky and be able to heat the block to 180C and walk away and come back after 30 minutes.
SaschaHanft 0
