Hi tommyph1208...
Your help much appreciated - thank you! I was planning on printing with black PLA but I'm guessing whatever filament color I use, applying some spray-filler will give me a smoother overall result once the shiny primer and gold layers are added. By using a black filament, will I still require the black shiny primer?
Do you recommend any particular brand of spray for the filler and black shiny primer? I'm pretty clueless to model painting
The filler i used was light brown/sand colored, so yes you would have to apply a black shiny primer on top before adding the gold... The black before the gold is something I picked up on Adam Savages (former Mythbusters host) youtube page. He is very into cosplay, props etc. and does these one-day builds of everything from workshop machines and items to cosplay armors, weapons and gadgets.
I don't remember the brand of spray filler I used, but its doubtful you would be able to find the same type anyways, since I live in Denmark and you are from New Zealand... It doesn't get much further apart than that
I would visit an auto-parts store and ask for it, see what they have... It looks and sprays like one of those spray-color cans, but is somewhat thicker. The one I used was intended for cars and similar to fill out dents etc. after eg. sanding away rust and before applying paint and varnish.
Edited by Guest-
1
tommyph1208 55
You need some primer first, to smooth out layers and make the paint stick.
I have previously had good results using first some spray-filler (for repair work etc.) to smooth out the print... The stoff layers into cracks nicely and sands well.. Then apply a black shiny primer before the gold finish
Edited by GuestLink to post
nzo 16
Hi tommyph1208...
Do you recommend any particular brand of spray for the filler and black shiny primer? I'm pretty clueless to model painting![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
