No settings are loaded from the machine. Cura is in control of them. In some cases settings do get sent to the machine, but never the other way around.
As for material temps; Materials have a "default" temperature. Certain qualities will modify them (and use the default temp as a base). Retraction is something that is overridden by the quality profile. Cura uses a "stack" approach to settings, so the top most setting holds the used value. As the quality (even though it depends on the material) is above the material, it's settings get overridden.
nallath 1,123
