tinkergnome 918
Or the spec of the capacitor-
Ultimaker has published the schematics long ago. You can use it as a start.
If i'm not wrong this are C36/C37: 100uF/35V
kegs 0
It says 100 VFP. 3B0 - not sue if the last zero is a "o" or "zero"
I was looking here-
http://www.newark.com/w/c/passive-components/capacitors/aluminium-electrolytic-capacitors/smd-aluminium-electrolytic-capacitors?brand=panasonic-electronic-components&capacitance=100uf&product-range=fp-series&diameter=6.3mm
