Issues with Cura vs Print Studio code, and filament extrusion
Posted
· Issues with Cura vs Print Studio code, and filament extrusion
There are many reasons why they might be different. The file on the left is ultigcode which does extrusion in cubic mm such that the same gcode file will work with either 1.75mm filament or 3mm filament. This works on UM2 series printers (not UMO I don't think, and not UM3 I don't think and not most non-ultimaker printers).
That's the most likely explanation.
Other reasons might be someone played with "flow" or filament diamter but probably it's the ultigcode things.
You can disable that in cura in the machine settings.
gr5 2,331
