Cura 2.x and 3.x Wall Line Count confusion.
2go
Posted · Cura 2.x and 3.x Wall Line Count confusion.
Hello,
same model, same settings. Wall Line Count set to 1.
Where does this green line come from in Cura 3.x?:) Thanks!
Cura 2.x screenshot:
Cura 3.x screenshot:
    There is a new setting in Cura 3 called "Extra Skin Wall Count" that determines how many extra walls skin layers will have. For some reason, they decided to make the default 1 rather than 0. So in all my profiles I have to go around changing it to 0 so as to get the same results as I had before.
    Thanks @smartavionics ! Worked perfectly. I agree that it should have been set to 0 by default.
    It would be so cool to specify different wall counts for bottom/top/rest of the print. Couldn't find such feature yet, I hope it gets implemented one day...
