Hello,
I had this problem already with 2.7 now its the same on 3.0. (at the momen with standard stettings. The image was taken from the second layer. It's not only at first layer. It apears all over the high randomly. Have you seen the big bulp in the structure? where the line starts? The lines in the empty room are not the big problem, but his part in the Structure is anoying alle layers after comming. Because the nozzle hits again. (Material on structure)
When problem appears, I hear the feeder working hard.
Anyway I'll try this option.
BR
gr5 2,189
What slicer are you using? In Cura 2.* you can enable "combing on bottom layer only". This will take care of that single line through that circle on the right. It will also take a little longer to print as it will avoid going across open areas but when it does go across open areas it will retract the filament.
