There's a company called Mosaic that does this in an automated way with a filament splicing machine controlled by the computer. While you print! It works pretty well. But it only works on 1.75mm filament. I think they tried it on 3mm filament and the color transition takes to long wasting tons of filament. So you would have to convert to 1.75mm filament if you bought this. 3dsolex could help you with that if you wrote them a nice letter (they could build and sell you 1.75mm cores to test out). Or I could if you lived in USA instead of UK. But converting a UMO or UM2 to 1.75 is quite easy.
I once tried welding 2.85mm pieces manually. It works, but it is cumbersome.
First, you need to design and print a sort of clamp or guide in which you can keep both ends of the filament aligned nicely. So that they match well while welding.
Then, cut off both filament ends in a 90° angle. Insert them in the clamp/guide. Heat a metal plate, and old knife, or a spatula in a flame until well above melting temp of the filament. Insert that hot metal inbetween both filament ends. Push the filament against the metal slightly, so it melts. Remove metal plate, push filament together, and let cool down. (So, obviously the "clamp" needs to keep the filament ends in place, but it also needs to allow sliding them. It should not be a tight clamping, but rather a sort of guide. And it should be one that you can operate with one hand, while keeping the hot metal plate in the other hand.)
Finally, cut away, sand, file or machine away the inevitable flanges. To minimise these flanges, don't melt too much filament, and don't push it together too hard. A hotter metal plate works better, as it takes less time to melt the filament's ends.
It works: it gives a strong bond and feeds well. But the removing of the flanges is very time consuming, because the resulting diameter on that spot should be close to 2.85mm. Too thick or irregular, and it will get stuck. Too thin, and you get underextrusion.
This is the "clamp" or guide I used. Clamping and sliding is done by pressing the filament down with my fingers. Very primitive, yes, but it was only ment for a quick test, not for production. For better results the filament should have been clamped over a longer distance, and with a top clamp too.
1
tommyph1208 55
I've seen it done with older UM versions, and it worked fine (interesting vases came out of that)
A few things you have to consider:
1. Use filament with similar properties, diameter etc. preferably same brand in different colors, check diameter with digital calipers and enter the average in your slicer. Same goes for print temp (different colors often print best at different temps, so try and find a temperature that works for all)
2. If you don't actually fuse the filament pieces together (quite some effort involved in that) retractions are obviously a no go...
3. Without pauses to reload filament pieces or a long fused sting, you are somewhat limited in the amount of filament you can print (one full bowden tube worth)... That is why stuff like single walled vases works well
