I have updated the text for now, similar to your suggestion.
could some intelligence be added to the "Print with Octoprint" button to check the gcode has been changed?
I have been mulling over that in the past, but never came up with an optimal solution. What I would like to do is to write an OctoPrint plugin to "un-UltiGcode" the gcode on the fly when printing. This would make OctoPrint UltiGcode compatible, so refusing to print UltiGcode would not be a good solution (anymore).
What I am currently thinking is, instead of showing the message "Note: printing Ultigcode using..." is having a checkbox that is set by default to actually switch the gcode flavor for you.
Yes, any automation that makes it a bit easier would be great.
I know I have forgotten to make the change (multiple laptops...I forget)...and then see the printer immediately starting to print when the nozzle isn't even heated up....first clue it isn't set to Marlin!
We don't often release an alpha version of Ultimaker Cura... So what's different this time? This Alpha contains such a huge slicing engine overhaul that we really need your help!
We wish to celebrate and honor the innovators that push forward the field, technology and world. We opted to not present it as a competition or ranked list. Every innovator has earned his spot on that list in their own way. We also look at the 3D printing industry as a whole and not limit the list to those only using Ultimaker.
ahoeben 1,109
LePaul 298
