However you should also over extrude to make the walls thicker. This is done automatically. [...] This is difficult to get .8mm traces out of a .4mm nozzle, but it works. Just print a bit slower.
Alright, if I wasn't interested in buying a new nozzle (I'm a bit cheap ), how thick could I print with a 0.4mm nozzle? (I have a Prusa i3)
Thanks for your time,
OfficialJoshTaylor
gr5 2,210
To make it water tight it really is best to do it in one single walled spiral.
However you should also over extrude to make the walls thicker. This is done automatically. So for example if you have a 0.4mm nozzle (what kind of printer do yo have? Please add to your account settings) and you tell cura the shell size is 0.8mm then it will doubly extrude.
Even better, use a 0.8mm nozzle or larger.
