it does indeed look like a CAD issue, use a boolean operation to merge all objects into one...
Cura sees the walls of your 2 objects separately and since they then intersect weird stuff happens in determining what is inside the print and what is outside.
Interesting to see that it's a mixing nozzle, what are you mixing?
we have someone here that prints those as well.
gr5 1,872
It's a cad issue. You could fix this with meshlab.
Or maybe there is a way in freecad to merge all overlapping objects into one object?
I know DSM. In DSM I select everything and there is a button to merge.
