Thanks for replying.
Ok, I will try lowering the bed temp.
I am using a product called dimafix to help with warping, most of the time it seems to help.
The only reason I am using ABS is because that is what I have (the machine isn't new, and the other material is XT-CF20). I thought PLA and ABS were 2 of the original FDM materials, so thought this would be easier than XT-CF20.
I missed a few other pics from my original post...
Cheers, Rich
Labern 773
That's normally when the bed temp is to high.
What are you using on the glass to help the AND stick?
Also is there a specific reason you are using ABS? It's not the easiest beginner material to use. It's also not as strong as PLA or other materials plus layer adhesion is not that great. So unless you really need ABS I would suggest starting off with PLA first.
