DidierKlein 729
Isn't the best way to do this with the per object settings? And infill mesh?
I did a small tutorial about it a while ago with cura 2.6
On 11/15/2017 at 11:30 AM, ahoeben said:TweakAtZ should be able to do that.
This plugin is no longer bundled with Cura. Is there anyway to get it in there?
4 minutes ago, dbantner said:This plugin is no longer bundled with Cura. Is there anyway to get it in there?
Yes it is, see Extensions -> Pos processing -> Modify G-code
Ok, it is named "ChangeAtZ" now, but it has the same functionality that "TweakAtZ" had.
Having said that, neither TweakAtZ nor ChangeAtZ can change infill parameters.
Instead, use an additional mesh to modify the infill settings using per model settings.
ahoeben 1,986
