My apologies. I am using a 0.6mm nozzle. That was a typo. I am using Cura 15.01.4 and an Ultimaker 2 that has been upgraded to an Ultimaker 2+. Additionally, both the shell thickness and nozzle size were input as 0.6.That pattern is classic underextrusion which can have many causes.
Nozzle size .06mm? That sounds like the problem right there. Maybe you want 0.6mm? If you truly have a .06mm nozzle then you need to either make the layer height smaller or the print speed much slower. Or maybe you have a .6mm nozzle but put .06 in the slicer (this print would take days I suspect if you did that).
Are you using cura or a different slicer? Which version of the slicer and what kind of printer?
Thank you.
gr5 2,210
