Can't unscrew Heater Block screw, that holds the temp sensor and heater cartridge
Posted
(edited)
· Can't unscrew Heater Block screw, that holds the temp sensor and heater cartridge
I had to wiggle mine back and forth(as in clockwise and counter clockwise). Then I gave it a good amount of pressure in the right direction and it came loose. Unfortunately my temp sensor was forever jammed in the block and broke off inside. I couldn’t remove the broken end and had to just replace the block with an olsson block.
Reznor9 0
Edited by GuestLink to post
