XY Dimensions to scale down without affecting holes?
Posted
· XY Dimensions to scale down without affecting holes?
There is a feature, "horizontal expansion" that can be negative. If positive it makes the part bigger on the outer dimensions but also makes the holes smaller.
You could combine an overall scaling of the part with horizontal expansion to control just outer dimensions, just inner dimensions or any combination of the two.
However, I wonder why your outer dimensions are typically .2mm too big. That is VERY unusual. Usually if anything the part is a bit small. Unless you are counting the very first layer? You can control horizontal expansion on the first layer only. In fact I usually set that to negative half the nozzle diameter or typically -.2mm.
If you mean the entire part is too big then I suspect you don't have a UM and you need to calibrate your X and Y axes more carefully.
1
gr5 2,070
