Posted · cura-3.0.4 support problem
I am trying to print a part that was last printed with cura-15.04.4. It requires both support and a raft. With cura-3.0.4, it will generate a raft if support is not enabled. Once support is enabled the raft goes away, expect for the area under the support. The model slices correctly with 15.04.4.
I think this must be something that I inadvertently changed because models that printed ok 2 days ago are showing the same behavior.
    Support is a set of commands or tools in the "Support" section.
    Brims, Skirts and Rafts are in the "BuildPlate Adhesion" section.
    They are independent and not related to each other.
    Can you show a screenshot of your settings?
