tinkergnome 918
I have another rather major issue though, which seems to be getting worse with each new update and getting to the point Cura is nearly un usable.. the stupid spinning beach ball ever single time I adjust a setting!!
I thought that's the main reason why "Slice automatically" can be disabled in "Preferences" for recent versions of Cura. Or does it not help?
ghostkeeper 105
A few things to clarify that you weren't sure about:
For version 3.2 I'm preventing the other printers from influencing the start-up time. It effectively only loads the metadata, which it needs to show the printer list at the start. Most importantly, it removes the multiplication of profiles caused by the definitions and materials. These are the feature_local_container_server branches on the Cura and Uranium repositories: here and here. Right now it takes about 1 second to go through the "Loading machines" stage of the start-up on my computer, down from 15.
Edited by GuestFix list; I'm used to ReST...
Thomllama 4
Cool! thanks for the extra info! looking forward to the update.. I have another rather major issue though, which seems to be getting worse with each new update and getting to the point Cura is nearly un usable.. the stupid spinning beach ball ever single time I adjust a setting!! I understand it's partially my older computer and slower/limited graphic engine (guessing here though) but honestly there isn't anything all the high demanding that Cura should be doing in that area.
