Thanks,
I do not think it was a problem with slipping. The guy before me printed without a problem.
I printed it 5 times. On careful examination of the printed parts the errors are repeated in exactly the same manner - ie reproducible. That's leaves the software to be blamed.
The only difference between me and the previous guy's prints was that I rotated it so that it layed flat on the bottom and that I have a different step file. And no, rotation by clicking on the circles was not easy (I do not know why).
Assuming the step file to be correct (as judged by the views) leaves only the created gcode to be in error. I did not find software to check the gcode for errors. Perhaps you know something that runs in windows or linux?
This was my first experience with the ultimaker and not even a good one!
gr5 1,872
>Can you guys make a simple command to turn parts 90deg?
The latest few versions of cura have this. There is a rotate icon, 3 rings appear around your part, pick the one to rotate by, then mouse drag until it says "90" (it prefers 90 over say 89 so it's easy to hit 90 perfectly).
>After a few slices, the ultimaker started to transpose the design.
Common problem. Do you have a picture? There are many causes. For example the part may have shifted on the bed in which case you need to get it to stick better by using isopropyl alcohol (wash the blue tape with ISA).
Or maybe the part did not shift on the bed in which case the "steppers slipped". Usually only in X or only in Y. Sometimes in both at once though - if both at once then there are bugs related to cura settings that you wouldn't think of such as joris - there's discussion about this recently. But finally we hit the most likely culprit:
Not tight enough set screws. You can test this by using a sharpie and put a little dot on all 6 pulleys (and shafts) that are used in the slipping axis (e.g. x pulleys if x axis slipped). Then after the slip the dots shouldn't line up. Tighten the hell out of the set screw for the slipping pulley. Or just tighten the hell out of all 6. Yes 6! Don't skip the 2 on the short belt (to the motor).
