3DSolex locked out
rebekah_harper
Posted · 3DSolex locked out
Hiya,
Just been trying to print with my 3D solex hardcore and it gives me a message saying incompatible.
I then have to override it via cura connect but it seems to override everything including the the xy offset.
I changed the offset by +2 and -2 with no change.
What have you done with the firmware that doesn’t allow third party cores?
It’s a big issue for me as I need it desperately to work.
Any advice would be appreciated.
Rebekah Anderson.
    You should be able to downgrade the firmware using the old files
    https://ultimaker.com/en/community/52037-downloading-old-um3-firmware-where?page=last#reply-193156
    Download tar and sig (signature) and follow the usb update instructions
    https://ultimaker.com/en/resources/23129-updating-firmware
    I don’t have a um3 anymore but in theory that’s how to do it
    I would agree with you there but when the print is offest by 2mm in the Y axis in the same direction. regardless of the offset within the calibration menu. I set it both to +2 and -2 and no change. I did do the calibration print and it was meant to be -2.
    so if it's not that then what could it be? it used to be fine but since firmware upgrade it's been like this. having said this it was only last night that I needed to use the hardcore so I hadn't noticed it.
    I don't think it would override the x and y offset, this is saved on the core eeprom, overriding is not a problem, it's just that the firmware doesnt detect the core as an aa or bb core
    Offsets are saved on a temporal folder on the olimex. They can be removed by restore factory or going ssh and swimming into that
