So it looks like the X axis is probably moving fine (and the extruder and Z axis) but the Y axis appears to not be moving much. I think it's probably a loose pulley set screw.
The Y axis has 6 pulleys and 3 belts. These are the ones on the left and right side of the printer that run front to back (that's 4 of the pulleys) and then 2 more on the short belt to the motor in the back left corner. Usually the problem is on those 2 that are harder to get. Hopefully you have the hex screwdriver or an L shaped allen wrench that fits those set screws. You can push the head around until the set screws line up. Then tighten them hard. Very hard. If you are using the green and black hex driver you can probably use your full strength. If you are using the little L shaped wrench your fingers should hurt after you tighten them. That hard.
You can also take a sharpie and mark the shafts and pulleys on the short belt to prove that they are slipping.
Your's seem to be slipping so bad, with power off you could try pushing the head to the front and rear of the printer and notice that the stepper doesn't always rotate.
gr5 2,210
