Hi gr5 - the bottom layer did break off - it started a bit sloppy but then seemed to tighten up as it increased in height. I've gone ahead and tightened the belts, made sure all pulleys are aligned and all belts are parrellel, I also replaced all of the grub screws with the replacements included by Ultimaker. I did it this evening so I will print another and see how it comes out.
Printed at "normal setting" via cura
Temp 210
.2mm layer thickness
50 mm/s
gr5 2,071
It's okay. It looks a little sloppy somehow. Maybe belts (especially short) need a little tightening? What temp and speed did you print at? Is this .2mm layers or thicker. Why is the bottom not filled in (bottom layer)? Did it break off?
