Go to expert settings and under "fix horrible" uncheck everything - particularly I think "type A" is checked. Uncheck that. This will fix your drill hole issue I think. I assume this is cura 15.* as that is what the screen shot looks like.
If that's not the only issue then try viewing your part in xray mode and check for any red areas. red is bad.
Also in cura consider right clicking on the object and try to split it into 2 different objects. Maybe? I'm not sure if that is what you want.
gr5 2,333
