kmanstudios 1,116
3 hours ago, gr5 said:Is the filament stuck in the UM core or the hardcore? Is it stuck when trying to remove the filament or only when printing or both? Which way are you *certain* is stuck and which way do you think might also be stuck? If it's stuck in the core how did you get the core out of the print head?
It sounds like you are describing a new problem just discovered with a few hardcores. The solution is pretty simple if it is the issue I'm thinking about. Also did you buy direct from 3dsolex or from a reseller and if so which reseller?
Could you be specific as to the issues discovered as I wonder if that is what happened to me with the copperfill I was using.
gr5 1,843
