Cura 3.x - bottom hole ignored
zfiser
Posted · Cura 3.x - bottom hole ignored
Thank you all for your replies.
Mine really didn't slice it properly, tried both 3.1.0 and 3.0.4 versions, even I had the "Remove all holes" unchecked.
Resetting profile settings to default helped, so I compared the before-reset/after-reset settings and found out that it was caused by "Make Overhang Printable" option enabled.
thanks again for your help.
