Hi Yellowshark,
Thank you for getting back to me.
seems like your suggestion doesn't apply, I couldn't find CURA under Appdata\Local\
I did find .cura under Users\"user name"\.cura\15.04.6
but there were only ini files.
I have also found cura folder in program files\cura_15.04.6 but none of the folder in it correlated to your suggestion nor did the have cfg / json files.
I've uninstalled and reinstalled cura but that didn't change anything.
yellowshark 153
With file explorer go to the Windows (c:) directory then the Users folder and select your profile directory. You want Appdata\Local\Cura\. You will see two folders “machine_instances” and “quality”. Your printer definition file goes in the first and your .cfg files into the 2nd. Now historically this has changed a bit and I do not have 15.04 installed on my PC so I cannot be 100% certain but I think what I have just said is correct.
You will probably see a printer definition for the Ultimaker in the machine-instances folder and some .cfg files in the quality folder. If not then I have got it wrong!
