If you post your Cura settings we will be better able to help you. For starters the primary ones are
Layer height & 1st layer height
Print speed and 1st layer print speed
Bed temp and 1st layer bed temp
Extruder temp
Is retraction on
Nozzle width
line width
wall width
Infill % and infill speed
Cooling %
Which material are you using and manufacturer
When you say poor quality a bit more info would be helpful, especially some pics! Which bits are poor quality - when you say poor quality what do you mean, gaps, stringing, blobs rough surface, poor circles or straight lines, etc.?
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
yellowshark 153
Extruder temp
Is retraction on
Nozzle width
line width
wall width
Cooling %
