Posted
· Flow setting influences lines in layer view
You could adjust your extrusion constant. This is a constant in your firmware, or gcode that relates to the mechanics of the filament drive. The correct value will cause the drive to feed accurately by length. It can be added to your start gcode if your printer is compatible. The code is M92 Exxx where xxx defines the constant. The correct value can be found by trial and error testing with Pronterface (printrun) console. Maybe yours needs a multiplier of 22 of whatever it is currently running. Search about fine tuning extrusion constant for more info...
mastory 44
shimmy 0
Thanks! I don't know what the default value is but I can see from my first test that this will work.
Edit: for anyone else who has my printer and wants to know, I ended up setting it to 235, YMMV
Edited by shimmyLink to post
