Hey,
No, I've not tried other cables or Programms yet. The car is about 70 cm long.
I would try and connect it to another program with that cable and see if you get a connection. Here's the link for Pronterface: http://www.pronterface.com/
If that fails, I would try a different/shorter cable.
I had the same problem for some reason with the newer versions of Cura - I now keep ver. 2.5 just for firmware updates!
Might be worth a try?
fbrc8-erin 265
How long is the USB cable you're using?
Can you connect the printer to your computer successfully with other programs? (Pronterface is a good choice.)
It could be an issue at the board, but it could also be a cable issue. Super long cables can time out while trying to transfer the data. Have you tried more than one cable?
