Please add a "CANCEL" or "RETURN" option to every screen
plebe
Posted · Please add a "CANCEL" or "RETURN" option to every screen
I have a UM3+. I find myself turning it off to simply cancel out of a dialog when changing print material or cores. Some screens offer "RETURN" which I used to bounce back, but sub-screens lock me into cutting the power to go back. For instance, I select Material 1 to load, it doesn't recognize my UM3 material, so I select manually, Oh wait, I can't go back. Power down.
I'm sure I'll get better at remembering the "quirks" of the new printer, but for consistency's sake, can you just ensure that there is a "RETURN" or cancel on each screen?
Thanks!
  • Like 3
Ok, then these issues still persist. I haven't encountered any lately but maybe I didn't hit some special cases.
If you want to help to improve the UM3 then please list all problems here - as detailed as possible.
Thanks!
I second this: add a RETURN option to every screen on the printer menus and sub-menus.
For example: I'm using non UM material, need to manually select the generic material, scroll a bit too fast and select the wrong one, then I can't go back to change my selection.
