Blank White Screen in Ultimaker Cura 3.1
Nicada
Posted · Blank White Screen in Ultimaker Cura 3.1
I just installed Cura 3.1 and when I try to open a file a different window pops up and stays blank. When I close it the whole program closes. Can anybody help me?
    The blank window is the dialog that is trying to tell you that Cura has crashed, but it has a bug in itself so it stays blank.
    What OS do you use?
    Could you try Cura 3.0, or the Cura 3.2 beta that was released yesterday?
    • 2 weeks later...
    • 2 months later...
    A usable workaround:
    Use Mesa-drivers for opengl instead of system drivers:
    DisplayLink drivers in combination with intel drivers seem to often cause issues with white/blank windows ;D
    • Thanks 2
    I created an account just to say thanks!! This worked like a charm.
    Thanks Geeky! I had the white screen on updating to 4.4, and your workaround worked like a charm :)
    I just wanted to put it out there that I had the same problem with 4.6.1 (oddly only on one computer). This fix worked like a charm.
    hi, i've tryed this with 4.6.1Cura, it's doesn't work for me, i still have a white screen and a "Ultimaker Cura (doesn't answer)
    i'm answer to myself , this solution work for me  : https://github.com/Ultimaker/Cura/issues/7779
