There are no settings to adjust speed and flow of bridges in Cura 3.2, yet. The awesome @smartavionics has been working on getting that supported in a future version; see the work in progress here https://github.com/Ultimaker/Cura/issues/1177 and here https://github.com/Ultimaker/Cura/pull/3175
13 minutes ago, lit-uriy said:Base speed: 60 mm/s
Do you mean "bridge" speed? What was the bridge speed in slic3r?
to gr5
History with settings looks like this:
I downloaded the configuration file for Slic3r from the manufacturer of the filament "Filamentarno!".
Printed in Slic3r.
Then in Cura 3, took the recommended setting for the 0.2 mm layer and changed based on The slic3r settings.
But I could not find where to enter the speed of printing bridges.
"Filamentarno!"/Slic3r print speed of bridges = 20 mm/s
37 minutes ago, gr5 said:3) Is it only the bridge speed that makes the difference? What happens if:
bridge speed = slicing speed
I don't know, I haven't experimented yet.
35 minutes ago, gr5 said:Do you mean "bridge" speed? What was the bridge speed in slic3r?
Not, the base speed is the speed at which all other speeds are calculated.
And correspond iner perimeter, nonsolid infil,
lit-uriy 2
to gr5
1) Full tower (1-Cura.jpg and 1-Slic3r.jpg)
Printer: Anet A8
Filament: SBS (manuf. "FDPlast", Moscow Russia)
Extruder temp.: 240 - 210 °C
Bed temp.: 70 °C
Base speed: 60 mm/s
Edited by lit-uriyLink to post
