kmanstudios 1,120
On 2/11/2018 at 12:06 PM, Ashen1982 said:Good Morning,
I just switched back to Cura from Repetier on my Maker Select v2. It appears everything is configured correctly but when I go to print, everything homes correctly and then the print starts approximately 15mm above the print bed. Any ideas?
Thanks
When you slice, what does it look like in the layer view? Is the actual sliced model above the buildplate or is it an error of distance between the software and machine concerning where the buildplate and nozzle is? Can you post an image of the sliced view?
AbeFM 35
Ashen, I believe I have seen this before - when 3.1 came out, I noticed the first couple models I loaded didn't sit on the bed properly - automatically "dropping" them drops them to the some imaginary plane, but nothing on the model.
I've had some come in under the plane as well, I almost wasted half a roll of filament for a missing cm off a bigger model just now. :-)
Anyway, uncheck the auto drop, and prepare for a world of frustration trying to get 100 micron accuracy placing the model on the bed. Sometimes it ignores the triad and just won't move the object till you grab "it" and not the triad - triad changes color but there's no reaction.
Hope this helps, anyway! Try another model.
