I am using Cura 3.1 and Extruder 1 is set for the build plate adhesion. Hence why I'm confused. It did it like after about 30 min into the print. Just very weird. I think it did it yesterday too because I was finding these burnt pieces on my plate like that had fallen off because when Extruder 2 was going the PVA filament was just curling and sticking to the nozzle.
kmanstudios 1,120
Can you post a dummy project file with just a cube or something like that so we can look at it?
Here's a file I know it did it on. It seems to happen right after the first layer goes down from Extruder 1 completes, then it switches to 2 for some reason, does a pass around the skirt then goes back to 1 and keeps on printing. Thank you for taking a look at this! Much appreciated!
kmanstudios 1,120
i am not good at the g-code yet. Others are though. But the project file would contain the models and settings. That is what I wanted to see. Hopefully someone will be able to go through the gcode and give you an idea.
tinkergnome 929
6 hours ago, appletart76 said:Here's a file I know it did it on. It seems to happen right after the first layer goes down from Extruder 1 completes, then it switches to 2 for some reason, does a pass around the skirt then goes back to 1 and keeps on printing.
It's tries to print a skirt with the second extruder.
I see that support is enabled (but apparently not needed?)), which one is the "Support Extruder"?
1
The support extruder is 2 but I don't have it checked off in the settings which is weird.
tinkergnome 929
Which slicer do you use? Cura?
Do you have - by any chance - the second extruder selected as "Build Plate Adhesion Extruder"?
