Thank you for reminding me about the older Cura, rowiac. That seems to work. I got my 3 squares printed nicely by moving the bed up a hair. This bed leveling wizard uses 210 C for the nozzle and 70 C for the bed - higher than my usual. I hope to get a successful test print! If you don't hear from me any more, I succeeded.
1
rowiac 50
I use an old version of Cura (v15.04.6) to do bed leveling. I haven't tried the newest version for leveling, but I like how the old version draws a large square on the plate to check the leveling after you have set the 3 points.
Assuming you are using PLA, try increasing your nozzle temperature to 200°C and set your initial layer height to 0.3mm, which is the default for Cura. Thicker initial layers are more forgiving of sub-optimal bed leveling. Once I have the bed leveled properly, I try not to manhandle the build plate too much removing prints, etc. just to make sure I don't disturb the setting. Usually I can go a long time before I need to level it again, although eventually the nozzle tip wears or something else will cause it to need re-leveling.
