Posted · Adhesion sheets are sticking TOO mauch
I bought a box with 25 adhesion sheets.
After printng an object I was not able to get it of the sheet.
I tried several things: heat the gals again, using water, put it in the freezer, etc.
Nothing worked.
To get the damaged sheet of the glas is a lot of work too.!
The sheets are not cheap and I cannot believe that the designers only looked to the capability of the strength of sticking.
The use of this product should be easy.
Did i miss instructions or is the product not so good as i expected??
    • 6 months later...
    Nothing worked.
    Did you ever manage to find a solution for this as I am having the exact same problem?
    Are you using PLA as material?
    If so, then don't do that, PLA sticks well to the glass (if heated) without anything or just with a thin layer of glue.
    Nope, I was using Formfutura ABS =\
    Have you seen this guide: https://ultimaker.com/en/resources/22187-how-to-use-adhesion-sheets ?
    Both applying and removing like this worked pretty well so far for me.
    Just to clarify, I'm not having a problem putting on or removing the sheets, I'm having a problem getting my ABS print removed from the sheet/buildplate.
    Ok I read the instructions, maybe I did it not properly.
    Bus what about getting the ABS off the sheet, like Nalith has a problem with too?
    Posted (edited) · Adhesion sheets are sticking TOO mauch
    Some people claim that few drops of water or isopropanol help to get the print off the sheet. You also could put the glass with the sheet and the print into the freezer, that helps.
    Edited by Dim3nsioneer
    IK thanks, I will try
    Did you ever find a solution to this?
    Edited by nmarach
    I'm havint the same problem.
    Easy to install and sticks amazing!
    ... too amazing.
    Can't get prints off (ABS).
    Tried the tips you find online, doesn't give an inch.
          • Heart
        • 4 replies
