Posted · 3.2.1 AppImage where to save Postprocessing Scripts
Just a, maybe silly, question:
Where should I store a custom-made postprocessing script that it will be recognized by the postprocessing plugin?
In 2xx versions - not using AppImages - I had the complete PostProcessingPlugin folder (including my script) in
.local/share/cura/plugins which works fine.
If I do the same in 3.2.1 I see the PostProcessingPlugin is loaded twice (I asume 1 time from the AppImage and the other
from my local folder) but my script didn't appear in the "Add a script" Selection list.
    Posted (edited) · 3.2.1 AppImage where to save Postprocessing Scripts
    AFAIK your custom-made scripts should reside in your local configuration folder, subfolder "scripts".
    Or more specific:  $USER/.local/share/cura/<Cura version>/scripts
    If your script does not appear in the list, there are perhaps some hints in the log file:
    $USER/.local/share/cura/<Cura version>/cura.log
    Edited by tinkergnome
    Thank you @tinkergnome,
    your answer finaly lead me in the right direction, placing the script in
    was unsuccessful and also was no hint in the log file.
    But, a little more searching  brought me to:
    $USER/.config/cura/3.2/scripts
    where I could succesfully place my script.
    Not that intuitive place for it, I think ...
