Alter print speed for surface area size under threshold?
Posted
· Alter print speed for surface area size under threshold?
In cura read description of the feature "minimum layer time" however you might want to instead print one or two Towers next to your print to allow the ears to cool more between layers. Towers will give you better quality.
Posted
Thanks! Somehow missed minimum layer time - doubled that hoping for some better results. Definitely will give towers a try.
gr5 2,194
Xillra 0
