Bug printing list thru printer direct access and Cura are wrong
Swissengineer
Posted · Bug printing list thru printer direct access and Cura are wrong
hello,
I'm having this issue since the introduction to cura connect.
I'm running latest firmware and software versions.
When I connect to the direct IP adress of our UM3E, the work in progress is completly wrong! And in Cura is the correct name, but the progress is also wrong. The only correct thing here is the screen of the printer!!!!!!
    I'm not sure when we fixed this bug, but we did fix some issues that look similar to this. I expect that it will be fixed with the next firmware release.
