Thanks as always @GR5, I did find the horizontal expansion setting. Also I've upgraded to 3.2.1. I'm setting up to use my single extruder UMO.
Below is an example of the sort of parts I am often asked to print. It s prototype part nest for automation. It needs to be accurate when finished. At first glance, you might think the best would be to split the model and glue. I have done that often on past parts. I would like to print as one piece instead of splitting and fabricating, so I can reduce hand finishing time, and remove the painstaking glue operation and chance for error. A longer print time is in my opinion cheaper than my manual labor.
This part is 45x65x105mm.
I'm considering a custom support model such as the red item below. I would like to figure out how I can print these two parts with different parameters defined for each body. I would like to separately control the red body to be printed at a high line density, but under-extruded and only a few layers thick on top of a support roof. Sparse auto generated support would be used beneath the red item.
I went thru all the support options in 3.2.1, and have sort of achieved the above with a support roof, tapered support, etc. I think I'm pretty happy with it overall, but I like to be able to under-extrude the support roof, or at least the very top of it. This could be termed as separately controlling the roof line width. I have not printed yet, just parsed all the slice settings and sliced. I'll start the print tonight. It looks like about a 5 hour print.
Edited by mastory
gr5 2,210
The easiest answer first: "support horizontal expansion". Set that to say 3mm and it will expand the support 3mm out horizontally from default.
If you are really printing lots of these parts and if you have a single extruder printer like the UM2 then I recommend you design your own support structure. I typically make thin walls that touch the outer edge of overhangs but every print is different.
Some of your questions are confusing (because I don't know what your model looks like) and I may have answered both questions wrong so please post a photo of your model if my answers aren't enough.
