Bug? Slicing Top to Bottom!
Uhlhorn
Posted · Bug? Slicing Top to Bottom!
Hi there,
since yesterday I use Cura and now I have a problem: Cura is slicing now from top to bottom. And I do not know why! I also not able to bring the normal behaviour back.
Does anyone have an idea what to do?
    Posted (edited) · Bug? Slicing Top to Bottom!
    Oh, I found the reason for this behaviour: It is possible to drag the sliver from two sides! And I pulled the wrong side!
    How can I delete a post?
    Edited by Uhlhorn
    I can delete this if you really want but I think this might be helpful to someone else?  But if you are embarrassed I'm happy to delete the post.  Just let me know.
    You can actually drag the slider from 3 sides; you can also drag the middle section of the slider, to move both top and bottom nubs at the same time
    • Thanks 1
