Cura 15.X used to have this wonderful feature where the last line in the file contained all the settings (meant to be read by a computer, not a human). This also allowed the great feature "import profile from gcode" which allowed one to alter all the cura settings to the settings used to make a particular gcode file.
Cura 2.X and 3.X don't do this. They don't write all the settings to the gcode file and they don't read settings from a gcode file. I suspect this is what you were looking for.
Instead there is a new feature called "save project". This is actually in some ways better than the old feature. It saves all the settings and also it saves the position and scaling of every part and it saves the contents of the STL files such that when you load the project all the parts are there on the bed in the same position/orientation and with the same settings as when you saved the project.
Therefore EVERY time I create a gcode file I also save the project. That way I can go back later and see the settings.
I'm not sure if this carries across versions of Cura (I think it mostly works). In other words if you save in cura 3.0 can you read the project in cura 3.1? I think maybe it mostly works. Not sure.
kmanstudios 1,074
I could not load it into Cura but it would load into Simplify 3D. Not sure why. I got no error messages. So, that is strange.....
